jetskiking
Im done sanding!!!
- Dallas Georgia
O.K. Im thinking Im going to do a carb mod. I already have on in mind but would like to here some input on carb mods Like Watercraft Factory, Jetworks, Etc.
Yikes.:bigeyes::bigeyes::bigeyes::bigeyes:unclehulka13 said:I have a 200 high and an even bigger low speed jet in my carb.
unclehulka13 said:i originally had a 200 high and 160 low, but it wasnt feeding enough juice low. so i ran it without a jet, and that was a bit too much. It would hit, but with delay. So i took a 140, drilled it out a bunch, and behold, it was there. I had Head Ent try a few diff things with that one, and i was very happy with the outcome. Whatever carb mod you do, you'll definitely be happier than with the stocker.
Also cant a low signal can make tuning a nightmare?SuperJETT said:Just my opinion, but if you have to run that large of jets, then you have a very unresponsive carb. The bore is too big, so it's lost the airflow/pressure drop so you have to run huge jets to let enough fuel in.
