- Forsyth County, GA
Was finishing up running the cooling lines on a stock engine SJ i bought a while back, and realized i did not remember to cooling line routing, and this manifold has 3 barbs on it. Can someone double check the routing i have?
1. Bulk head to bottom line on manifold
2. From the top fitting on the manifold to the head fitting
3. ?? There is a third fitting that comes off the side on the mani that faces the midshaft. I ran this to a pisser, is that correct?
my old mani only had two fittings that i remember, just making sure this was done correctly? Or does anything have to be switched?
