Quick question???? lifters!
CoreyLKN
LKN Freestyle Militia
Lake norman, nc
I have some homemade lifters and i want to install them and ride a while before my ski sells. I've heard alot of people say screw them in. When i do this do i drill pilot holes first or do i just screw the screws in?
thanks
-corey
meatball
User Title Unavailable
Maryland
YES drill pilots, otherwise the fiberglass will crack! The best way of attaching things to fiberglass is to use bolts.
demolition_x
Not After Fame & Fortune
i read some where that some one glued them on with some type of glue, and they held up pretty well.
and i also saw some one through bolt them. in the fire extinguisher hole and then through bolted to the out side of the tray on the other side.
up to you i guess
