Blaster quick steer?
It is a mod you do yourself so it doesn't cost anything but your time. It helps the blaster turn a lot sharper and in my opinion makes it even more fun to ride. I only did the pump part of it because I couldn't get both mods to work together because my cable wouldn't reach but I think if I made some adjustments I could get it to work together. Here is the link for it.
http://www.wavejunkies.com/surf-survival/doctors-corner/92-mod-blaster-quick-steer
Sent from my iPhone 4s using Tapatalk
The pump part is really easy and only takes a few minutes while the steering stem parts takes a bit longer and some minor fabrication. As far as the pump part just take off the black plastic steering nozzle and unscrew the little pivot nut that attaches the steering cable to the nozzle. Then just get a drill bit that is the same size as the hole and drill a new hole closer in and put everything back together
thanks alot for the help guys, has anyone ever ran an extended nozzle with trust innovations trim? if so how is that combo and does it give you alot of throw
I have a thrust trim set up for my xfs so I can fit it to my blaster and I have dave701 industries quick steer so I will,test it out and let you know how it goes ...........
Protec still sells a nozzle with a few adjustment holes on it. I got lucky and found an old ocean pro. It appears to be no were near quick steer but the arm is flat so it will be easy to drill for it.
