re-condition prop or toss and start over?
Need some advice. I have a skat trak 9-17 prop that has been chunked up via some rocks at the launch ramp. Anyone have any experience with Impros or can recommend someone similar ? Is it worth throwing upwards of $100 at this, or should I hang it on the wall as a souvenir and start shopping the used section?
They can actually rebuild missing surface area as advertised ? I took a couple good knicks out of the leading edge of it, in an act of desperation I ground it down a bit to try to flatten it out and eliminate the cavitation issues, but to no avail, it hooked up, but it about rattled the ski apart it was so imbalanced.
Quinc
Buy a Superjet
California
Correct, they weld it back up and smooth it out. I sent a Solas in really bad shape, they welded and re pitched it for 120$
I've had SBT weld up/resurface impellers for me.They did an excellent job. Costs $69 and that includes return shipping. Can't understand how they do it that cheaply (one week turn around)
yamanube
This Is The Way
Staff member
Mandalor
I think it really depends on what kind of prop it is, if it is a straight blade 9-17 old school prop, you can probably get a nice replacement for less than the cost of getting it fixed. If it is a radial blade prop like a hooker, swirl, concord, then getting it fixed is probably the most economical.
OCD Solutions
Rentz, GA
That $70 bill mentioned above is the basic rebuild cost. I should warn that if the outer diameter is out of spec and it needs to be welded up and turned down, that will be an extra charge. I sent a 140 Skat Swirl impeller in to be repitched and cleaned up last year and just about chit a brick when i got the bill. It was still cheaper than getting a new prop as it wasn't a common size or pitch but if you happen to have a common sized impeller, you may likely find a better deal to just buy good used. Just do your homework first.
