Really hard MSD Totall Loss guestion
alright... ill try to be clear because subject is bit hard ( at least to me)
here it goes...
i have tl in my 701 superjet, it is older version (4272) that has 1 coil 1 tricker and two magnets in flywheel.
now my problem is that this box is burned.. i have one newer box (2530) but it has only one of three channel working..
so guestion is can i use that new box with only one channel working with my current setup
i hope for fast reply.. like always everything fails just before big events like this one next friday..
which coil do you have? the blue pro coil or the red motorcycle coil? the 2 magnets and single trigger should fire fine on the new brain. just bench test it.
McDog
Other Administrator
Staff member
South Florida
I don't think it will work. Your curve will be off by a factor of two. I don't think you can set the rpms high enough on the brain to compensate.
waxhead
wannabe backflipper
gold coast
Let me explain it better.
Every time it gets a pulse the ignition thinks its done 360 degrees the two magnets will make it pulse every 180 instead
so when it think its done 20 degrees its actually only done 10 on the crank
I do have one kawi 300:rolleyes:
So there is no way to fool that loss to work with components that i have.?
Hmmm
How about remove other magnet and add one tricker then wire those trickers both to that one working channel?
