I ride in fresh water.
Manual has these specs...
- Loctite 271 (RED) for 7 engine mount brackets bolts, exhaust bolts, and some 4 engine mounting bolts...
- Loctite 572 (WHITE) for 6 cylinder body bolts, 10 cylinder head bolts, 8 crankcase bolts, coupling nut, impeller and coupling.
- Loctite 242 (BLUE) is to be used only on the reed bolts, Ride plate bolts, and reed valve bolts.
Those of you who claim to use anti seize on all bolts, you don't have problems with bolts falling out?
Did anyone substitute Loctite 572 (WHITE) for Loctite 242 (BLUE)? Loctite 572 is pretty much the equivalent of a pipe sealer.
