Super Jet Rebuilt motor making weird sound
kawa js550
Billy Racing
Michigan
I just rebuilt my 61x/62T motor this winter with new pistons, crank, seals, and gaskets. Before I rebuilt it, a shop said that one of my crank bearings was bad because it was making a loud rolling noise. I just took the ski out today with the new motor and if I get around to 3/4 throttle I hear it again.... I would go faster to see if it does it at wide open, but I am in the process of breaking in the motor rn. Could the cases be causing this noise? That's pretty much the only thing that hasn't been replaced.
Is your motor and pump properly aligned? That could cause some noise if not. I wouldn't install a new crank of one of the bearings was making noise. Does it make that same noise on the trailer? How about if you pull the plugs and just turn it over, noise?
kawa js550
Billy Racing
Michigan
The only time I will hear it is if its in the water and going around 3/4 throttle. Maybe im hearing the mid shaft or the pump, but everything is aligned to my knowledge. It doesn't do it on land or if the plugs are pulled, so now im thinking its the pump or midshaft
khaos
Party in a can!
Tidewater, VA
Just ride that poop till it breaks. I know one guy who's had an SBT motor for a few years and it is still going strong. Maybe, this will be #2. I mean its already in and its summertime. Get the thing wet.
That aside none of this is meant to be a slam. Simple stuff gets us when we get frustrated.
Are motor mounts tight? Are they good? Is the gas poop? Low octane gas esp ethanol gas that is old is harder to ignite and can 'act' like the timing is retarding. Pop the head or a plug and get look in the jug for ugly. Ride it flat for 5-10 minutes keep the water out and afterwards check for excessive heat on the coupler. See if the rubber is super squishy/gummy. Are the plugs resistor type? Replace them with new or non for testing, that carbon gets a crack in it and the suck starts. Are they the right plugs? plug# not match the box#? (that one was earned on a box of 8) Are both pistons from the same company @ the same type? (We do things here in junkie country we are not proud of just to ride) Are they installed facing forward. (prolly, it would run like poop before 3/4 throttle if that was the case.)
It could just be the crank is out of balance. :(
smoofers
Rockin' the SQUARE!!!!
Granbury, TX
I've got SBT cranks in all three of my skis. Two of them have been running strong for 5 years (SJ and HX). The HX was raced for 3 seasons on the SBT crank and at this point has a couple hundred hours or more on it. If they were such garbage why would Jetmaniac sell so many of them?
hhh
not saying they all are, ive known of plenty run for a long time. i just got a junk one out of the box and trashed a brand new rebuild
