Reccomended pistons for my 61X
Because they're Pro-X pistons (same maker) for much less.
Go with whatever is affordable, except WSM.
sneaky
a real mickelson
PNW
are there any down sides to running oem pistons? i'm building basically the same setup but was told to go oem because of the fitment consistency.
BROSS
The future right here
Lake Norman, NC
Oem is almost twice as much as a Pro X, if keeping the round top piston Pro X all the way, never heard of sudco making pistons but if it says ART inside its made buy the same company as oem or pro x, go for it. My $.02.
Pistons
I have many Pro-X piston kits in stock...Call me and I will see whats available.. Don't send me a PM from here, as I don't check it often.. You can contact me directly at wcc@watcon.com also... 360 692-3492
Drysuits in stock. Used 62T cases $200.00.
Thanks,
Randy
WFO Speedracer
Alabama
One more thing I have installed many WSM pistons,I have never seen a piston related failure in one of them,years ago maybe but not in the last 6 or 7 years.On stock or lightly modded applications they work fine as does PROX,SUDCO,OEM or any other piston.They hold tight mfg tolerences as far as sizing and seem to be made as well as oem pistons.They also use RK rings which is what PROX uses as well.If you are building a high dollar race or rec engine then I reccomend you use use high dollar pistons,in that application I use WISECO which work fine as well as long a proper piston to wall clearances are used.
