Lifted from greenhulk...
Comparing Signal Statistics - Having made all these different statements about the importance of signal, the next logical thing to do is post the actual signal data (as measured on a flow bench). Nearly each of the aftermarket carb makers produces (and strongly promotes) the 44/46mm butterfly versions of their line. Given this, we considered it most relevant to list the data for these diameters. The only exceptions were the Buckshot BRM (they promote the 47mm instead of a 46mm), and the Keihin 42mm (the 42 is the largest race carb that Keihin makes).
The following data was gathered on a Super Flow 600 flow-bench set at 20 inches of water for all tests.
Along with this data, we have also denoted the full throttle CFM numbers, as measured at 20 inches of water. They are listed in alphabetical order by carburetor brand name.
Carburetor (signal@100%open) Main Circuit Pilot Circuit CFM @ 20" (100%open)
Buckshot Magnum 44 31.0 23.3 268
Keihin CDK II 42*** 28.8 22.5 195
Mikuni Super BN 44*** 49.0 30.0 230
Mikuni "I" Body 44*** 32.2 22.5 239
Novi Max Flow 44 66.0 25.7 269
Red Top 44 37.9 20.3 269
AMC 46 31.7 21.5 293
BMR Full Spectrum 46 58.0 23.0 299
Buckshot BRM 47 41 - 47.5** 20.5 293
Buckshot Magnum 46 37.2 26.0 286
Mikuni Super BN 46*** 46.0 34.8 253
Mikuni "I" Body 46*** 33.0 23.2 246
Novi Max Flow 46 65.0 28.0 304
Red Top 46 34.8 21.0 296
** The signal reading randomly fluctuated on a 2-4 second cycle within this range, with no stabilized 20" reading lasting over 5 seconds. Signal reading would not stabilize until pressure was reduced to 8".
*** Tests were run with bolt-on arrestor adapter.
So here's my take,
If you look at the Aftermarket SBN 44's and 46's they produce the best low speed signal out of the box than any race carbs in this guys testing posted on the greenhulk forum.
I'm not saying stock super BN are the best...just they will work very well on all kinds of modified engine setups, big cc or little cc. I have found that the CFM flow of the carbs IS NOT the primary concern for me but rather how clean and crisp the engine response is after lots of throttle stabbing that freestyle/freeride riders do for pulling off tricks.
One of the reasons I say to use the dual 46's even on stock modified 701cc engines, compare the low speed carb signal on the 46 to the 44...46's had more signal!
From this guys chart HE tested the novi maxflow as the best CFM flowing carb with Ed's Full Spectrums in second, Now keep in mind the specs are probably outdated to the current modified carbs today. But overall a decent test with a flowbench.
The best setup I use for Pro freestyle engines (Race fuel/MSD-TL/all the goodies) has been the new Novi Freestyle 48's. (just don't use their spec's/develop your own)
Chuck
