I have a Dasa 850, twin 46 full spec, B-pipe , the package has less power than a stock 701
the manifold of the b-pipe was port match , the jetting of the carbs is very rich 14o high speed ,low speed 130,NS 2.0, spring 80 ,
we also have the water manifold , the plugs are lean, the engine is hot , we look every where , we replace the base cylinder gasket , the o-ring from the boyesen manifold where replace,
But then I remove the manifold to check the reed valve and I saw that the bottom valve did not close properly ,
can this cause all the problems
