There was/is a low tension return spring sold by hot products.
I'm currently running a 1/3 less tension spring on FS49'S that I got a good while back from jet world a site online. Been running it for years on 46's too and it really helps with carpal tunnel.There was/is a low tension return spring sold by hot products.
Can you bring some to Daytona? Need one for the Freak. Thanks.In stock at JM
You only run one on aftermarket duals, they are usually coupled together with a good design.Is just running one not advisable? Do people run two on aftermarket duals?
Always run one. Pop it off the retention casting with a screw driverIs just running one not advisable? Do people run two on aftermarket duals?
Done, much better. Thanks all.Always run one. Pop it off the retention casting with a screw driver
