cycojon
addicted to my superjet
- riverside ca
i am replacing the top end on my 62T/61X because it was worn out, i read alot about air leaks caused by old crank seals...
what needs to be taken off to replace the crank seals? i would guess, the flywheel, and the coupler? i already have my motor out and top end off so...
i shouldn't have to split the cases right?
anything else i should look at? the reeds are new, i might as well replace carb base gaskets and intake gaskets while im there, but the crank bearings feel great as well as the rod bearings.
thanks!
thanks!
