I am installing a B pipe on my superjet this coming week......will I hit the stock rev limiter with only a pipe? I´ve heard it is set lower on the newer models....I have the stock stainless prop (its a 08).
You might hit the rev limit a lot more with the B pipe. You can have the stock CDI modified to have a rev limit adjuster or you can replace it with the MSD Enhancer that has a better timing curve and an adjustable rev limit.
