- Cleveland, Ohio
Here is your chance to own a "like new" Rickter Edge Carbon Core. I purchased this hull new and didnt receive it until 2021. I completed the build and hit the water at the end of 2022. Its only seen water 2 times as i dont ride anymore. This is my favorite "all around" riding ski. I have flatwater flipped it as well. It is titled as a Rickter Edge. The majority of the parts were purchased new.
Here is a break down of the build.
Hull. 2018 Carbon Core Rickter Edge. Has RRP rear sponsons (new). The hull is nearly flawless. It has a couple rub marks from on and off a stand.
RRP Light weight pole with carbon fiber RRP tubes. RRP ninja chin pad. New ODI grips, RRP bars, etc.
The drive line.
Dasa 950cc 8mm stroker. Bored over so its closer to 1000cc. Engine has 1 ohio season on it since it was rebuilt.
Power factor pipe (new)
Full spectrum 50mm carbs (1 season old)
OEM yamaha electronics with MSD enhancer and jetinetics flywheel
Torrent 155 magnum pump paired with custom skat prop. (all new)
Thrust 155 trim with aluminum nozzles (new)
Ski is located in Ohio. Shipping is available but pickup is preferred. If you have any questions or would like more pictures or videos, just ask.
$27000.00
The drive line.
$27000.00
