- St. Croix River
Does anybody know if the case bolts from a Riva girdled head could be used instead of the studs/nuts on my Ada girdled head?
Thanks
I gathered from the "True Girdle Kit" thread that people have a problem with the bolts snapping. Bolts seam easier to deal with than studs and they look more sano. I don't have any complaints with my ADA head.
Are studs generally more stout than bolts?
riva hardware blows monkey ass. if you have ada hardware , use it.
while the concept behind rivas hardware seems very logical, THEY SNAP.
riva has produced both 2pc and 3pc girdle hardware.
ive had more problems with the 2pc than the 3pc.
the lower parts kept snapping flush at the case.
This is an old kit obviously made by a machinist. The holes are not cut to deeply. Long capscrews seem to be made of 416 ss. I don't know who sold this.That is the hardware I am using, I thought they bored pretty deep considering the thread ends a quarter inch before the bottom. Major engine failure, that doesn't sound good.
I have this riva girdle kit and it just caused engine failure. Four of the studs broke at the weakest point displayed in the drawing by AUGUSTAF while riding. The cylinders seperated from the cases and filled with water and scoring my cylinders. Now riva is not offering a replacement. Does any one know where to get or who is making replacement studs that are quality, not looking for the ADA? The reason I do not want ADA is because you break the seal between the cylinders and the cases if you remove the head.
Any input would be appreciated.
