Riva Rear Exhaust Install
phoenix
Hi,
I got a Riva rear exhust for my Blaster and was wondering if anyone still has the installation instructions lying around. Mainly just want to know exactly where to drill the hole in the transom?
Can anyone post pictures of theirs?
Thanks,
James
phoenix
Actually that helps alot, centered over the duckbill, about 1/2 inch up. Looks like one RIVA on top, two on the sides, with a slight bend in the tube that helps with the orientation.
THANKS!
how in the hell you actually do this, do you have to take out the motor and firewall and stuff ? i want to do this and redo the trandsom at the same time never done it before though
phoenix
No just take out the battery, tray to access the inside of the hull where the ruber exhaust hose meets the exit. Then remove the rideplate and pump so you can unbolt and remove the old exhaust exit.
I also took out the fire extinguisher tube just to have a little more room to work but probably not necessary.
I will post pictures sometime this weekend.
THANKS FOR ALL THE HELP!!!!
