Riva Red Pipe prob
Paul Walnuts
Bak on The Blaster
South Jersey
I had a problem starting my blaster. i had just put a primer first it started right up and then the second time i had to give it a full pull on the throttle to get it to start, but when it finnally turned over i got a load of what seemed to be a mix of carbon and oil (black muck) come out of the pisser. i dont know if one thing had to do with another or if it was just a coincendence. any thoughts, also is there any flush i could run through to clear out the exhaust. i use a blowsion adapter that back flushes through the pisser to flush out.
