i have run the pole with washers, or i could make you delrin adapter bushings to make up the gap. will most likely still need to grind the pole or bracket or the pole wont go up very far, about waist high on me without grinding. i suggest doing it to the pole because the bracket isn't very strong to start with.
pm sentPm me about that bushing idea, that's cool with me. I can see in mock up some issues bottoming out, but I have no problem hick grinding poop for -2 lol. I wanna try it.
Watcon sells a pole bracket to allow you to do this as well
I had one on there and chopped another 4" out of the round nose pole and had some cold fusion steering. It was perfect like that
Same cable (SN or RN) will work.What did you do for the steering cable?
