Rockered SuperJet w/ all the goodies
SN SuperJet chopped and rockered. Filled bond line and reinforced with S-Glass from front to back. Tray was completely re-foamed and all reinforcement is there too. Bottom reinforced with RovenWoven. US Composites Epoxy systems were used. Epoxy painted engine bay. 61x/62t fresh build bored 1 over non-ported. ADA Girdled Head(pump gas), Aluminum Water Box, ODI Grips, Primer, 1 way valve installed to drain hull quickly, Reed Spacer w/ V-Force 2 Reeds, 12 Vein Mag Pump, Hooker 9/17, Jetmaniac HD drive shaft, new OEM Starter, new midshaft housing, MSD Ignition and Coil Pack, bilge pump, aluminum Handle Pole -4”, widened tray w/ footholds, B-Pipe. Powder coated- cases/black, cylinders/black, header and head pipe/orange, B-pipe/black, fly cover/oran. Ocean pro nozzle and deep scoop intake. This ski has had 2 tanks run for break in and tuning. The head pipe screws do not function. Head pipe was removed and sand blasted to install Jetmaniac Oversized kit. I have not completed the head pipe. This ski will come with a single trailer.
$4,500 - Located in Mobile, AL
