Rockered WaveBlaster with JM Big Bore 790
Rockered Big Bore! Fresh rebuild at the end of last season on a Jet Maniac Big Bore 790cc, 86mm pistons. Rebuilt from the crank up! Will consider trades for a 1-up or 2-up Sea-Doo Spark Trixx.
$5.900 - Located in Waconia, Minnesota
- JetManiac Big Bore 790cc
- Factory Limited stainless pipe
- Dual 38mm carbs, rebuilt last season
- Fresh epoxy hull (figured I'd freshen it up while rebuilding the engine)
- Carter B Gen 3 Rocker, front and rear
- UMI Steering / NXT LVL Bars
- Solas Mag Pump
- Hooker Prop
- CATS Trim
- Chopped/Lowered Seat
- Custom Foot Wedges
- Dakine Foot Straps
- Worx Scoop Grate
- Lithium Light Weight Battery
- 3D 1" Nozzle Extension
- MSD Enhancer
- Lightened 61x Flywheel
- JM Midshaft Housing
- Dual Bilge Pumps
- Hydro-Turf Traction
- MN tabs updated through 2026
Trailer not included but EZ Ski hitch hauler is also for sale for $300 more.
