Did the coupler fit, from pipe too mani ?If done the reverse of this before. It worked easy. Only thing is OD of rrp stinger is about 1/2 inch bigger.
yesDoesn't the rrp manifold have a spacer welded in where the pfp pipe would slide into the manifold, rrp pipe just butts up flat?
