RRP Pole Tube Vinyl Wrap Template
If you're like me and would rather not spend $250 on real RRP carbon tubes, Purchase the finest carbon fiber vinyl and use this 3d printed cutting template to give a seamless transition from tube to the clamping ends. The bottom has a flat boss that will keep both clamping templates clocked correctly. Slide them to the length needed, tighten the bolt down to lock, and trim. I originally used a quick paper template that got me close, but trying to get both ends clocked correctly didn't work well. I purchased 1.5' x 5' vinyl on amazon that ends up doing four tubes. The print is on thingiverse for anyone to use.
