Custom/Hybrid Rrp rear fuel tank
uk
I've just bought a second hand rrp fuel tank hardly used but came with no instructions on how to pipe fuel lines up ??? I'm running a fuel tap and cold fusion tank at the moment, has anyone fitted one before and how did you pipe it up thanks phill
eastcoastjumper
James
Long Island
Are you using it as the only tank or adding it to the cold fusion?
If using with the front tank,
Pull the supply's to the carbs off the rear tank middle fittings. Pull 2 feeds off the front tank and run lines to the top and bottom fittings of the rear tank.
Returns from carbs go to the front tank, and use your one way valve on the front tank.
The front tank is pressurized from the returns and pumps to the rear tank which is under vacuum from the fuel pumps pulling.
uk
As you use fuel the front tank empties and the rear tank stays full keeping the weight closer to the rider.
Is there a advantage to this running fuel to the front tank ??? Ionly ask as my edge rides better on full tank keeps nose down better
Sent from my iPad using Tapatalk
uk
very tight in there
