Vumad
Super Hero, with a cape!
- St. Pete, FL
I am running the Rule 500. I am going through a bilge every year. I seem to be having more issues with impellers coming off the shaft than anything else. I don't have stuff getting stuck in the pump. I keep my hull clean and clear. The only thing I can think of being a problem is running them dry. I run them non-stop in the surf and when I am trying to learn flat water stuff like subs. I take on some water and my ski pumps as needed but does run dry a lot. I have the stock siphon and don't run the bilge unless I am doing something that might hurt my boat if it is not on (have bar mounted switch). My bilge on my SJ is just about a year old and is not working. I haven't pulled it out but it runs but doesn't pump water. The last 3 or 4 bilges I pulled out of my X2 ran but the impellers had come off the shaft (also lasting about 1 yr). I took them out and they just flop around in the housing. What's going on here? These things are $35 each and I hate spending the time to replace them.
