- Central Ny
Just got back from the lake and went to run the engine quick to kick out any left over water when the engine started to runaway...
Caught it all on my dash cam in my truck (well at least the noise)
I let the engine cool down and checked compression... 125 in each cylinder. Engine still turns freely. Hopefully nothing warped from the heat or rpms...
It runs but sounds a bit rough. Turning the engine without the plugs in sounds no different than before.
Where else should I be checking for damage?
Did I get lucky and shut it down before any real damage I wonder...
It ran about 45 seconds WOT(or at whatever crazy rpm it was running off to) without water...
I guess I'll find out next time I get it down to the water :/
edit... original video never loaded
