Cannibal
Tasty Human
- Summit Lake, WA
So I was talking to a guy who's been a PWC mechanic/tuner for 28ish years. He said one trick on the 650/750 engines is to remove the base basket and run a thin bead of 1211 instead. This does a couple things.
1: Moves the ports down to help with the high ports Kawis have to increase bottom end.
2: Increases compression 20ish pounds, so no need to run after market head.
Has anyone done this with any success? Anyone have problems not running a base gasket?
