Sanding hydro-turf
Endo
Non-tree hugger
Heat? I've used it for cutting but never sanding....so heat it then sand? And Crammit what Grit you thinking? 220 seems to tear it and 400 doesn't seem to do ********.
Sospikey
Trying to get upside down
Sweden
Be gentle with the paper! I'd go with 220 and an easy hand. Use that to get 90% of the shape, then use 400 for the smooth, baby-a** feel!
What's the best for shaping hydro-turf padding? Having a problem getting it the shape I want without tearing it.
i use a scotch bright pad with a three inch grinder works perfect. you can get most scotch bright pads at hardware stores, i get mine from my snap on tool dealer. brown work best.(corse):fing02:
i've had harder time with the gray matting. i use black close cell foam. grings much better with out doing the mealting/ ripping thing
crammit442
makin' legs
here
I'm thinking 40ish grit. It scuffs to whatever shape you want it. When you're done sanding, wave a heat gun over it and it will largely clean up all the fuzz from sanding.
crammit442
makin' legs
here
thats what i do. it helps to have a small twist regulator, at the air inlet of the grinder, to govern speed.
...and plenty of beer:beerchug:
I actually use roloc pads on a die grinder for mine most of the time too. My projects always have redbull instead of beer though.:biggthumpup:
Endo
Non-tree hugger
A little die grinder with 3" pad is what I used on most of it. I think that is what I am going to stick with it. I was just trying to clean up where the discs won't fit...be honest I am probably just being a little overly anal with it.
