amemoryoncelost
X2/SNsj
- tacoma, wa
So I smooshed my SN at the end of this summer, throttle got stuck, long story, whatever. So I got a new hull which was missing it's turf. Well, my ski had perfect turf, so it was gonna be a waste to just throw it away. Here are some pics of me pulling the original turf off and how I did it. Sorry for the quality if it's an issue, taken with my iphone.
Tools I used: One xacto knife, bottle of goo gone spray(citrus smell) and gloves.
Basically I started at one end and worked my way to the other side. The rails are only glued on at the top and backside as you can see in the pics. Everything else should pull right up. As you pull up, keep spraying the goo gone at the seam and it should pull up. I worked pretty slow, the faster you pull, the more the turf wants to stay connected to the ski, which is where you're gonna have issues. If it did try to stay glued down, just run the xacto knife along the edge and you should be good. As long as you go slow, shouldn't have any issues. On the backside I was having some issues with the glue, but I don't think it's going to affect how the turf feels when it gets put back on.
I know most people here would rather have hydroturf, but I like the stock stuff and until I throw in footholds, might as well save myself some serious money. Hell, I may even try to use this stuff when I do put them in. Figured it would be a good post for someone who wanted to save it for some reason (painting, new hull, refoam) and needed a little inspiration.
Good luck!
PS yes, that's half a hull. The smooshed part got cut off since it was basically done for and I can pick this up and move it around.
Good luck!
