SBN 44's: All the same?
Regarding single 44's, as opposed to those that came paired (or tripled) up as part of an OEM ski, are they all the same? I did see in the Hot Products catalog two 44's (called 44MM) with different part numbers: 53-2060S, Mikuni #BN44-40-8067, and 53-2060 Mikuni #BN44-40-8052. Maybe the 'S' just denotes it's silver in color, as the picture shows? Thank you
dfw
The 8067 and 8052 are aftermarket carbs with extended throttle shafts. I think they're the same except for color and jetting but Im not 100% sure. The 44s that came on 650 superjets have 4 pilot holes and 701s have only 3. They both work fine but would require a slightly different pilot jet or pop-off to get the same part throttle mixture setting. OEM Yamaha 760 and 1200 racks have 3 hole pilots and the longer 1.60 throttle plates. They also work fine but will tune slightly different than the aftermarket 4 hole carbs with 1.20 plates.
john zigler
Vendor Account
wisconsin
OEM carbs are different than universal off the shelf carbs. OEM carbs are made by mikuni to the manufacturers specs for that specific engine, to meet EPA standards, etc. Internal circuity is different, throttle plate angles are different, etc. They will work on other applications but are not always the best option, and can be harder to dial in.
The only difference in the Hot Products carbs 8052 & 8067 is the color and jetting. Either will need to be jetted for your application. Not once in my 37+ years of building watercraft have I found an application where these run as is out of the box.
waxhead
wannabe backflipper
gold coast
You're spot on—the four holes are actually called progression ports, and they help the carb transition smoothly from idle to the high-speed jet. The early models had four instead of three, mainly due to emissions regs, but the four-hole versions actually give better throttle response.
It’s not like people haven’t been doing this for years in Lite SuperJets, running WaveRaider carbs with the extra progression ports.
Personally, when it comes to 44s, I love the stock 760 setup—it’s cheap, dials in beautifully, and just works. Yeah, they’re emission-style carbs, but with reverse jetting, they hit harder than a divorce lawyer with a grudge!
Most excellent replies! I've been involved with riding and racing since the mid-80's and never knew any of this. My reason for asking is I'm putting together a trio of 44's for a SXR800 to 1100 swap. I have 2 core 44's (still need the 3rd one) I am going to go through. How can I ID what I have to make sure they're good-to-use?
ATL
Anyone ever see a 44 like this???
Completely threw me off guard. Seems identical to an OEM Yamaha 44. But no formed oring... Just takes rubber gasket
john zigler
Vendor Account
wisconsin
Make sure all three are identical..... If you are on a budget, and want to use OE carbs, get all three from the same ski. (IE 1994 SJ 701, etc) or better yet source some OE triple 44 carbs. Yamah 1200 non PV engine for instance came with 3 sbn44's. If it were me, I'd just get three new 8052 SBN's and be done.
Seems like a nice set of gp1200 triple 44's would be the way to go for this. They're relatively cheap, you know you have three matching carbs and then you'll have a nice OEM linkage and the experts can correct me if I'm wrong but I think that gets you the kidney bean piece with less dribble too.
ATL
certainly cost wise
What I'm running in my 1100B1
Major pain though however
Triples are sweet but not for the feint of heart
Thanks to the group for your great responses. And mrfist9, thanks for the pic. I had heard there were numbers in that area, but I did not find because they're so small. And, covered with grime and black paint in my case. Scrapped that goo off, and found what I wanted: These 2 I have are stock 44's off of a 61x Yamaha engine. See the attached spec sheet. They're identical.
ATL
i'd just find a 1200 non pv rack
RHAAS sells an adapter plate
I'm running that with 3x Pro-k filters
there's a facebook group of specifically 1100 swapped SXR800's tons of good info there
