- Lake Stevens, WA
I plan to install an SBN44 on my 1991 X2 that is currently running a 650 with a CDK II 38. I also have limited FX1 (Factory Pipe, 144 Pump) and I like the idea of both my skis having the same Carb (stock one rebuild kit) . . . also hoping that the 44 will give me some incremental performance benefit on the X2.
I do not want to tweak linkage on the SBN. I also want to use my stock X2 cables. What is the shortest path for me doing the install on the X2? Options as I see them:
1. Can I modify the stock X2 650 intake manifold to accommodate? What needs to be done?
2. Purchase a SBN44 adapter that I have seen listed from time to time for around $50.
3. Purchase a differentX2 650 intake manifold. Recommendations?
Ski has a WC Pipe, WC Head, Factory Water Box, Decent Pump w/15.5 Impeller. Desire is all around good performance with a preference for low end grunt.
Share your wisdom please.
Thanks!
Thanks!
