- New Brunswick, Canada
There’s a sleeve over the end of the crank right there. I believe it’s just the sealant/adhesive that holds it in placeAnybody know what this black ruber build up is on a SBT reman crank for a superjet is? I understand using a bit of bearing retainer, but this seems wrong??? View attachment 409182
It's a Redi-Sleeve to fix a damaged crank seal surface. The crank was damaged before they rebuilt it and this is how they fixed the seal surface. Probably just sealant.
Redi-Sleeves
Timken offers Redi-Sleeves, which are precision stainless steel wear sleeves designed to be pressed onto a shaft for an enhanced sealing surface. Redi-Sleeves are fast, inexpensive repair options for grooved or worn shafts.
Design Attributes
- Timken’s line of Redi-Sleeves feature a strong, durable stainless-steel construction that helps create a corrosion-free sealing surface that may surpass original shaft specifications
- Redi-Sleeves have an ultra-thin construction of 0.25mm (0.1″) that allows the original seal size to be used with minimal additional lip loading
Applications
- Redi-Sleeves can be used on a full range of industrial equipment
I have an OEM crank I'll check when I get home. In the OP picture you can clearly see the sleeve and sealant and is not part of the as-cast crank.It sure looks to me like this is an oem part on all cranks, not a redi sleeve to fix damage.
Is that not what everybody above in this thread is saying, and also what is shown on Yamaha parts fiche?
Kawasaki uses a sleeve as well in the exact same spot...I have an OEM crank I'll check when I get home. In the OP picture you can clearly see the sleeve and sealant and is not part of the as-cast crank.
I honestly don't know if Yamaha installs these on OEM cranks or not but other OEM's don't. Others like Kawasaki and Seadoo either run a seal directly on the machined iron surface or have a large sleeve sealed with an o-ring.
Yamaha shows a #4 Sleeve but it looks thick.
Correct as I said. But they are much thicker than the one in the OP's picture.Kawasaki uses a sleeve as well in the exact same spot...
I didn’t notice it on the original crank before I sent it out for rebuild. Obviously it was there. This one is back in the motor now. Just waiting another 6 months for a b-pipeThere is a thin sleeve there on OEM stock 701 and 760 cranks, same as in your pic. It is called a drive shaft collar.
