SXR Scoop grate fit all sxrs
XFT LOU
1 hp./1.83lbs
St. Louis
Hi will a 2003 scoop grate fit on a 2006.
I'am pretty sure Sxi years are different
I notice with the Sxr 's the one brand name has different part numbers for '03 - '06.
Thanks
screaming440
The Old Skool Professor
the two main sxi pro/sxr bottom differences are the sxr is a little longer and the pump tunnel is longer. the sxi scoop is a few inches too short to fit the sxr. the ride plate is interchangable.
XFT LOU
1 hp./1.83lbs
St. Louis
Thanks , I was shopping and the owner was confused .
We measured the distance of the frt to rear and it was a Sxr Worx's scoop
It came the other day , all good !
