want me to make you one? i can if you give me some dims to work with and a better idea what you want.The max slides into a tube I need one that screws to the outside of the hull.
So essentially you want one of these but with a larger ball in a 1 inch size?
Right now the size is larger then I would like and stock is more expensive then I anticipated. Working or rev 2 now to get the design smaller and more affordable. WhileAh gotcha...should work well than
