Server move!!!!!
SuperJETT
none
I've had it with our hosting provider. We'll be moving sometime next month.
Based on Anthony's recommendation, I'm going to try dreamhost. If they don't work out, pm him!!!:sneaky:
Anthony
Clever custom user title.
New Jersey
LOL!
You should see if when they set you up if they give you a temporary URL to access the site on their servers if you aren't 100%. Of course you always have 97 days and like I said, so far no problems here.
Anthony
New Jersey
I emailed Dreamhost to let them know the premiere PWC site was going to move to their servers and not to let me down :biggrin:.
Anthony
New Jersey
They changed how I refer people to Dreamhost now.
Use this link and don't enter anything for who referred you:
http://www.dreamhost.com/r.cgi?14612
--or--
enter the tartaglia as the promo code
EDIT: Or don't its up to you. This should help though if you were trying an older link and having trouble. Hopefully that clears things up.
SuperJETT
none
As mentioned, I pretty much hate our hosting provider's service. We'll move soon.
And Anthony, can you be a bit more aggressive?
Anthony
New Jersey
And Anthony, can you be a bit more aggressive on making sure you get a cut or what?
I'm not trying to be aggressive at all. A friend was trying to use the old link and apparently the process changed and we had about 5 emails back and forth of me trying to explain the old way before I realized it changed. It just added confusion and wasted both of our time.
You don't have to use the link at all and nobody else does either. The referral isn't worth me being perceived as "aggressive" I was just trying to save somebody else some time if they tried.
Good luck with everything and no worries.
SuperJETT
none
We're back on the old server for now. It appears there is a problem with the theme or a plugin that I didn't have time to find, so I switched back.
I'll probably point x-h20 to the new server and work on it then point x-h2o to it once it's functional. That way, it can be an immediate switch for everyone just by going to x-h20 until the dns propagates for x-h2o to work also.
BTW, I found out during this that some people go to x-h2"ZERO".com then get redirected to here, which is the proper address, x-h2"OH".com. Water is 2 parts Hydrogen, 1 part Oxygen, so it's H2O. I have the other domain set to redirect to here.
