Setting carb
jps
FRANCE 64
hello
I need a base for a setting carb for my DAsA SS 850.
I Want to put on boyesen intake with two 46 mikuni GRS carbs.
Do you have an idea for The setting?
I'm not familiar with DASA motors..... But normally 1 full turn out (360 degrees) on highs and lows is a good starting point. If it hesitates off idle go richer, blogs/loads up go leaner in the lows. Make sure your idle is set where you want it. That will make a big difference. Also you can call DASA and they should be able to give you specs.
