Watch that. It's a long ass video but he explains how he started doing flat water backflips and shows you how to set up a wake. This is how I learned as well
Your setup wake is going to mimic the letter "U". Take your ski and try and make the letter "U" in the water. Try making it big or small then dial it in to see which way makes the biggest wake for you. Its all about timing. Also, pull your trim lever while making the U. It will make your waves more aggressive.
This is probably the worst video you will ever see but you can kind of see the set up wake.
