So I'm getting ready to shave the hood on my X2 and while I'm at it I'd also like to knock down the steering cover piece but I've got a few questions to the guys who have done this:
1. When you filled in the hole for the trim dial did you ditch trim all together or rig something up that still fits under the short cover? Pics PLEASE
2. When you filled in the fuel selector did you just ditch the switch all together and just run the reserve fuel line directly to the carb?
3. When filling the hole left by removing the hump in the hood do you lay the glass mat from the inside or across the top on the outside? If you lay it from the inside how do you bring the edges up level with the outside?
TIA
TIA
