Shaving glue in hull .-Sxr
Okay so I just about finished my hood . Now moving on to they hull I wanna remove the foam that holds the tank and waterbox in place to shave they glue up in the nose area . So here's the question can I remove the foam that holds my tank and water box in place ? Reason I want to is I wanna free up some hand room to get in there and shave . But if I take it out can I put it back in or is there a better solution as to a replacement for the tank and water box foam holder ?
The foam is just laying there, it should come right out once the tank and wb are removed. I used a L- head grinder with a 36 grit sanding pad on it to remove the extra glue. I worked well and was fast but made a huge mess, def do it outside with glasses and mask...
Yea I'm doing it now I hope it makes some what of a difference in weight . I can't afford a a/m hull yet so I just gotta shred what I got .... Hopefully I lose some pounds
Ya it's not a big gain, I didn't weight mine before and after but I saw a thread where a guy cut away every single bit that he could and it cut off 4lbs... A lot of work for not much gain but along with the other stuff you can cut and trim to save weight it all adds up.
