SkiDiggity
formerly kawirider142
So I am at the point where I trying to shim my motor and just cannot get all of the teeth of both couplers to line up.
The motor is in with bolts to hold it in place (loosely) pushed all the way back. The first thing I notice is that the tooth on top that is connected to the midshaft is about 1 mm higher than the coupler on the motor. So I shim the motor with a 1mm shim on each mount. Now the tooth on top attached to the midshaft is just about even with the coupler on the motor.
I spin the coupler around to the next tooth and it's too high again, as if I need to shim the motor more. If you look at the two teeth that are now on the side they are off as well.
I watched the wamaltons video online on how to shim the motor and they make it look super simple. I just do not understand what I am doing wrong. If i can get everything mostly even will it be ok? Or am I going to end up blowing out my midshaft housing because I cant get all the teeth to perfectly line up?
Please bestow upon me your knowledge oh great X and help me get the freshly rebuilt turd on the water this season.
Thanks,
Shane
Thanks,
Shane
