I just want to talk this one out to make sure my thinking is correct. I’m going to align a 155 pump in a KDX. The engine is set back an inch but still uses a SJ midshaft so the shaft just gets pressed into the housing further. So this means the driveshaft doesn’t even protrude inside the hull so when you bolt up the cold fusion tool, it makes it useless.
What I’m thinking, since I already rebuilt and assembled my pump, is to use my wear ring and reduction nozzle along with a buddies stator section. He has a 155 that hasn’t been touched yet so it still has a couch shaft in it. I plan to align it like this and keep up with how many shims I need and leave my wear ring bolted in place and remove the rest. Does this sound ok or is there a better way?
