Blaster Shortening throttle cable
mattyboy89
The countdown is on
im looking to shorten my throttle cable as the new trigger i bought lets it max out to the bar end when fully adjusted back. can i just cut it and recrimp/solder on the lug that goes into the trigger?
yamanube
This Is The Way
Staff member
Mandalor
It seems unlikely that an aftermarket lever does not allow you to adjust the slack out of the cable, I would look at it again. If you still can't make it work, do what Jetmaniac said and get an aftermarket throttle wheel like this one.
