Looking for some assistance here for a friend's ski, was hoping you guys could help out.
94 B1
Motor is a 61x
Single 44
B pipe
ADA head...though compression is a bit low on this motor. (~130?)
145 high/120 low, 95g spring, 1.5 n/s.
Ski was dying while using it. Rebuilt the carb and was acting similar. Swapped in a fuel pump from a spare carb and now it runs well.
The problem I'm having is from 3/4- wide open throttle it's dying, as if there isn't enough fuel. From idle to 3/4 it runs just fine. The jetting is the same as it was originally, the only thing changed was the guy had what looked like an 80g spring in it before. I have the high adjuster all the way out and it still dies up top. Have tried it in all positions.
I think the 145 jet is the right one to use, so I'm confused. Any ideas on where to start? I'd think this is a simple one for some of you. Thanks!
94 B1
Motor is a 61x
Single 44
B pipe
