sitting on the hood of a 650 sx.
Dubs chops
livintit dot com
is this a bad idea since the pole isnt flush with the hood like on a sj? i weigh 200 lbs and wouldlike to know before i jump up there and crack my hood or pole.
The pole doesn't sit flat on any hood there is a gap. The conatact points are the pole mount and the shock pad near the back side of the hood.
But to answer your questions.. jump up there you won't hurt anything.
subseawellhead
Cherry Bomb Jackazz
Louisiana
Used to ride mine sitting on the hood backwards, from there....it's easy to go into a headstand in the tray. Forward vis somewhat limited at that point
