Does anyone know the thread spec (thread pitch and length) of the SJ case bolts tht hold the cylinders to the cases please? I would like to order some replacement Allen key types.
You'll be spending a small fortune. And if you buy stainless (likely your only choice for corrosion resistance; OEM's are plated bolts), the metal is often so soft that you will eventually round out an Allen bolt.
