Can someone help identify this flywheel? I pulled it out of a 650 superjet so I am guessing 6m6. The magnet configuration looks different from anything else I have seen
Harbor is correct, you're the lucky owner of a 62T f/w used on Raiders starting in 1994 and on Superjets in 96. Someone presumably "upgraded" your 650 before you got it. It's somewhat larger on the inside diameter and has to be used with the corresponding 62T stator
