SJ Parts, ADA head, SN pole conversion, tubbies etc
Wisconsin
This is basically a complete part out. Was going to pursue this project but deciding to back out. Please message me if you need more photos. I know I am missing a couple pictures, working on getting everything in here.
Please plan to pay shipping and PayPal fees if you choose goods and services.
1 - New b pipe chamber coupler $15
3 - ebox mounting brackets $10
9 - coupler cover $10
11 - New unbranded sponsons, resemble destroyers $200
15 - oem 144 pump stator section $30
22 - OEM fuel fill $15
24 - NEW HSI squarenose to round nose pole conversion bracket with oem hood hooks - $215
26 - throttle cable $20
30 - squarenose chin pad $15
43 - 1994 superjet hull and hood that I can either sell outright now, or I was planning to fix it a bit to make a build be a little more palatable to someone. $200 as it sits. Currently the tray is ripped out and defoamed, side of hull below the water line needs a repair, and somehow the Midshaft mount area got damaged. Not sure how, bought it like this.
45 - 0 degree handlebars - silver - $40
46 - NEW Complete ADA girdled head - Blue with 35cc domes, o-rings, and girdle kit $325
47 - NEW Push industries intake grate - $125
48 - OEM starter solenoid - $15
49 - reworked 08+ SJ prop, repitched to 10/16 for lites class - $175
SOLD ITEMS
2 - Superjet length midshaft shaft only with coupler $100.
4 - new 2x Mikuni 38’s, never ran $250
5 - 62t intake with new two-stage boyesen reeds - $75
6 - 62T cases, excellent condition $160 or $175 with bed plates
7 - standard bed plates $20
8 - 61x flywheel $50
10 - ebox halves $30 for both
12 - Oem starter $50
13 - drive couplers $30 for both
14 - 61x exit nozzle $35
16 - jap bearing pump rebuild kit $60
17 - oem wear ring $25
18 - superjet driveshaft $125
19 - oem crank seals $40
20 - waterbox rubber straps $40
21 - OEM round nose waterbox $175
23 - superjet fuel tank $100
25 - steering cable 90-07 $25
27 - flywheel cover $10
28 - protec 61x adjustable rev limit cdi $125
29 - AC racing -2” aluminum round nose superjet pole $350
31 - UMI steering system $100
32 - Pole limiting rope $20
33 - 4x rubber strap hooks for tank, waterbox, etc $20
34 - NEW 2x KP rubber isolating pads for waterbox (to be used with oem or AM strap hook) $20
35 - NEW lynx 94+ midshaft housing (from JM) $115
36 - 61x cylinders need bore but good condition overall $75
37 - oem ride plate 90-07 $25
38 - oem hood latch hull and hood side $15
39 - oem engine mounts $50
40 - gas tank rubber straps $40
41 - 90-95 superjet long exhaust tube
42 - 90-95 fuel fill tube with gas cap
44 - Squarenose in tray fire extinguisher bottle holder $30
Wisconsin
Tubbie fit up on hull if you are skeptical. Green stuff is just mold release. Finish is gel coat. Pretty happy with it actually, should be perfect once hardware is installed.
Wisconsin
Still some good parts for sale, dropped prices to probably what they will remain for now.
Feel free to make an offer, willing to offer some price breaks on multiple parts.
