enzo
How's the waves?
The stainless wear ring on my back up boat pump has swolen and froze the impellor. Was working great until it sat for a couple months. Is there a 'Back yard' fix for this? Or should I send it off to have a new liner put in.
New oem only from Yamaha! Plastic ones suck, they won't last very long and your back to where you started...
speaking of, what should the clearance be?
I fear mine is larger than it should be. ( freshwater, no swelling liners to deal with)
Ketsair and I had jokingly talked about brushing epoxy all into the pump to decrease the impeller tip to wear ring gap.
I might try that.
