- N.Carolina
I just did a rebuild after 10 years on my sn superjet. It’s got the usual set up of Factory Pipe, ADA head, MSD enhancer etc. I’m running dual 46 mm Mikunis.
I broke it in for an hour last weekend then switched out the plugs and ran a tank through it. It ran perfect. I got a solid 3 hours of great riding out of it
Today was a different story. It revved up fine on the trailer but when I put in the water, it would not rev up. It would idle on the water but would not go over about 3000 RPMs when I gave it full throttle. I checked the plugs and the front cylinder is running rich. I swapped out plugs and it did the same thing. The coil is a new rebuilt one so I swapped the plug wires and it still did the same thing.
I tried to search the subject but I’m not coming up with anything so any help would be greatly appreciated
Thanks
Steve
Thanks
Steve
