bondra131
Thaat's braptaastic!
- Coeur d'Alene, Idaho
Been deal with this for a long time now... It isn't the carbs; I sent those to jet works and had them looked through, rebuilt and correctly jetted and set up for my build. I have tuned 5 times since then and I get it running great then go out riding the next day and it is instantly rich as can be... Hardly runs and I find fuel inside the engine compartment when this happens. I can lean out the low speed circuits and get it running well again for the day but the next time I ride... It's crap again. Only thing I can think of is an air leak but I can't imagine how this is possible since I thought I had an air leak, tore it down and found a bad crank seal. Did brand new seals yamaha brand ones and used yamabond on the cases and every single gasket on the motor is brand new. Yet still having head problems... Sometimes it idles down after a rev up out of the water, other times it holds it's rpm's for the most part and very slowly winds down and not to idle. This is when out of water. Another thing that says air leak to me but I can't imagine how . I literally tore it down THREE TIMES and resealed the cases. Twice with one set and then found stripped threads in a case bolt, bought new cases that are in very nice shape and all new gaskets again and it's still doing this bs... Anything else that it can be besides an air leak? I'm lost here and very frustrated. Haven't had a good running ski for two years now and I'm getting pissed lol
